Hello experts,
Resetting trial office 2007 error occurred. When I uninstalled my trial office 2007 because I just reformatted my computer with an operating system of windows 7 64 bit operating system it has an error occurred and unable to let me install it back again, the installation process freezes. I hope you can give me the best solution for this problem.
Thank you.
JayeTan
The best way to your problem is to uninstall office 2007 completely there are still files/parts of the programs that left behind when you uninstalled a program if you are not sure where to remove this files you can use revo uninstaller to scan your computer and it will show you what files are left behind you can download it at https://www.revouninstaller.com/ you can use if for 30 days free trial.
-Jaye
mennae
you  can follow this steps and I am sure  your problem wilbe solved ,First note that
 the following steps involve modification of registry key values ,which may corrupt your windows if done incorrectly .backup registry Then do this stepsÂ
 close all Microsoft Office programs
click on start button , then click on RunÂ
type regedit in the Run  text box  and click ok or press EnterÂ
locate and then click the following  subkey
HKEY_LOCAL_MACHINE SoftwareMicrosoftOffice12.0Registration
Inside, you will find another subkey that resembles the following subkey:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftOffice12.0Registration{30120000-0011-0000-0000-0000000FF1CE}
