Resize And How To Compress A JPEG Photo Online
What is a JPEG photo? How to compress a JPEG photo online? Is there any software for compressing the photos?
The term JPEG is the acronym for Joint Photographic Experts Group. There are many websites where we can resize and compress a JPEG photo like jpeg-optimizer.com, compressjpeg.com, compressnow.com and much more. The steps involved in online photo compression are,
Step1: Choose the browse button and select the photo that you want to compress or resize
Step2: Select the compression levels like width, height, and size you wish to convert to. You can crop the image also
Step3: Click on “optimize now” button to see the optimized image and download the image to your desired location
There are many software’s that are available for image resizing and compression like Caesium Image compressor, JPEG Compressor, FileOptimizer, PunyPNG, JPEGmini, etc.
JPG (*.jpg) is a file extension for lossy graphics file while the JPEG file extension (*.jpeg) is used interchangeably with JPG. “JPEG” stands for “Joint Photographic Experts Group” and they created the standard. JPG files have two sub-formats: JPG/Exif and JPG/JFIF. JPG/Exif is frequently used in digital cameras and other photographic equipment. The JPG/JFIF sub-format is often used on the internet or the World Wide Web.
The JPEG standard specifies the codec. This identifies how an image is compressed into a stream of bytes and decompressed back to an image but not the file format used to contain or hold that stream. The Exif and JFIF standards define the commonly used formats for interchange of JPEG-compressed images. JPG files can be opened by almost any image editing applications from Microsoft Paint to Adobe Photoshop.
