Hi expert, I need a help. How resize hard drive with PGP. My friend told about this. But he have not proper experience about it. If you know about this please give a proper ideas and send some helping tutorial explanations.
Resize hard drive with PGP
Hello Kristin Runaldou,
It is so sad to tell you that there is no software at all which can resize your hard disk device physically.
But the partitions are resize able. You can resize the partition as you desire.
The resizing of a partition can be possible with partition utility.
You should use Partition Resize in this regard. Please go to the following link to download this software.
It is much easy to use.
Download Partition Resize.
Thanks
