zoyaaharoon
10 points
Posted on - 12/19/2012
Hey, I have Huge pdf scans on mac system. Size of each scanned image in Pdf file is very huge. I want to take print of each image on A4 size page but only partial image is being printed every time. I want to resize page (Image) of PDF file. I am looking forward if anyone can help me to guide that How I can get print of whole scanned image (page) on an A4 size page.
Resize Pdf Scans on Mac to print a hard Copy
Hallow Zoyaaharoon,
I have not cleared about your problem .If the screenshot of your trouble can be seen then it will be better.
By the way you can upgrade to Mac OS X 10.2.3 or later.
Starting the print queue may allow documents to print.
1. If you see the message above, click Continue.
2. If your document does not print, follow the steps for Mac OS X 10.2.2 below.
Mac OS X 10.2 through 10.2.2
1. Open Print Center (/Applications/Utilities).
2. Choose Printers > Show Printer List.
3. Select your printer.
4. Choose Printers > Start Jobs.
Documents should now print. If not, go to step 5.
5. If the queue stops immediately after being started, check the printer and its connection to the computer. One of the following issues may keep the printer from being able to accept or complete a print job:
Thanking you
Shifflett Laurel
Hello Zoyaaharoon,
You can open the PDF in Preview and select "Save As" from the file menu. The "Quartz Filter" menu will give you the option to reduce size. If you want to take it further you can add Quartz Filters using the Color Sync utility.
You can use Nuance PDF Converter for mac. This software features industry-standard PDF viewing, resizing, editing, and security. PDF Converter for Mac also features accurate PDF conversion to editable formats using Omni Page, the world’s best-selling OCR technology. PDF Converter for Mac also includes direct savings to cloud services such as Ever note and Paper port anywhere.
Combining unparalleled functionality, 256-bit encryption, and ease of use, PDF Converter for Mac enables users to edit and securely share PDF files as never before.
Thanks anyways...
Greaney Mary
