Resizing controls not working in Citrix Multi Monitor
Hi All,
I am in need of a small technical support or advice from my Techyv Friends. I am using the Citrix Multi Monitor and is having issues with Configuration Settings, Resizing controls not working in Citrix Multi Monitor. Please advice on how to overcome this issue.
Thanks in Advance,
David
Answered By 65 points N/A #136642
Hi David,
Multi -monitor, also called multi-display and multi-head, is the use of multiphysical devices, such as monitors, televisions, and projectors to increase the area available for computer.
To be able to use resizing controls, make sure device is connected to nonseamless sessions. For enhancements and new features you can download Citrix Online plugin for Mac 11.2 Release note. Due to vast enhancements, citrix multi-monitor act like native windows workstation using multi-monitor configurations. This resulted to the no longer use of all configuration registry flags.
