Resolve An Error Occurred During The Installation Of Assembly Component Problem.
This error comes through many cases and like that due to the missing operating system. When we try to install MS office 2007, then we get an error occurred during the installation of assembly component error. Can you solve this?
Answered By 0 points N/A #294453
there are many steps which help you to remove it:
  1. Firstly, restart your computer and again install it.
  2. If you have used Windows seven, then update it to Window service pack 1.
Image result for an error occurred during the installation of assembly component
  1. Download Microsoft .net framework from the official site.
  2. Also, download and install Microsoft Visual C++ and then follow the troubleshooting guide from Microsoft.
  3. Hope these steps will help you.
Answered By 590495 points N/A #315156
This error normally happens when the program you are installing is not compatible with your computer. Before installing Microsoft Office 2007, check that your computer meets the requirements. Microsoft Office 2007 supports Windows XP Service Pack 2 or higher, Windows Vista, Windows 7, Windows 8.x, and Windows 10.
Though Microsoft Windows 10 is not officially supported since this is the newest operating system and Office 2007 was created many years ago, Office 2007 is certified to be compatible with Microsoft Windows 10 that is according to Microsoft. Older versions of Microsoft Office such as Office 2003 and earlier are not certified to be compatible with Windows 10 but might work using compatibility mode.
Installing Office 2007 will allow you to use the following Office applications: Office Access, Office Excel, Office Groove, Office InfoPath, Office OneNote, Office Outlook, Office PowerPoint, Office Publisher, Office Visio Viewer, and Office Word. Microsoft Office Word is a widely-used commercial word processor designed by Microsoft which was first released on October 25, 1983 using the name “Multi-Tool Word” for Xenix systems.
It is available either as a standalone or as part of the Microsoft Office suite. Microsoft Office Excel is a spreadsheet application included in Microsoft Office suite.
