Resolve Canon Fax Error Codes Briefly
When you sent or received any document, then an error code is displayed on the screen. Give canon fax error codes. Can you please tell me error codes?
Answered By 0 points N/A #290404
If you sent any document then an error code is display on the monitor.
You can check fault codes and take the required step to solve the problem.
  1. Error 200 = fax session completed without error.
  2. Error 221 = press stop key, to terminate the fax session.
  1. Error 227 = a local machine initiate a fax and machine does not support.
Hope this would help you and solve your issue.
Answered By 590495 points N/A #302803
Here’s a list of error codes without messages in a Canon fax machine:
  • #001 – there are two possible causes for this error: you scanned different sized originals but you did not set the Different Size Originals mode or you scanned different sized originals in the 2-sided original but you didn’t set the Different Size Originals mode. To fix this, set the Different Size Originals mode then scan again.
  • #003 – you may receive this error code when the communications took longer than the preset 64 minutes time. To fix this, decrease the resolution of the document or split the document into two or more parts then try sending the document again.
  • #005 – when you receive this error, it is either the receiving machine is not a G3 fax or the recipient didn’t answer within 35 seconds. To fix this, verify that the recipient’s machine can communicate then try again or check the recipient’s type of machine.
  • #009 – you may receive this error when the fax machine has no paper or the paper drawer is not properly inserted into the machine. To fix this, load paper or insert the paper drawer properly.
