Resolve Error 0x80070571 The Disk Structure Is Corrupted And Unreadable Problem.
Whenever I am trying to create or delete anything and any folder in D drive, then I got such type of error message error 0x80070571 the disk structure is corrupted and unreadable. This fault comes through either file or folder. Resolve it?
Answered By 0 points N/A #294462
The disk structure is corrupted, or unreadable problem is caused by the link between hardware and software. The software allows windows operating system to communicate with hardware.
These types of error simply resolve uninstalled and again reinstall disk drive in device manager.
Then press the Window key + R for a run. Type diskmgnt.msc and press enter.
Image result for error 0x80070571 the disk structure is corrupted and unreadable
Expand disk drive, Right click on which partition that creates such type of problem and uninstalls it.
Confirm and click on Action.
Answered By 590495 points N/A #326977
If you keep receiving an error saying something like “disk structure is corrupted and unreadable” every time you try to delete something on your hard drive or on a particular drive, try checking that drive for errors with PC Tools. Download PC Tools Performance Toolkit and install. Once installed, start PC Tools then go to “Recovery” tab and click “Repair Drives”.
On the next screen, select the drive you want to check. From the options, select “Surface Scan” and check “Perform on reboot”. Click “Start” then “Continue”. Exit PC Tools then restart the computer to begin the check. The checking will be quite long depending on the size of the drive and the extent of the problem. If bad sectors were found, try repeating the scan a second time.
Bad sectors are normal for hard drives like IDE and SATA and usually appear as the drive gets old. If bad sectors appear everywhere on the drive and the drive is quite old, it means you need to replace the drive with a new one.
