Resolve Error 1324 The Path My Pictures Contains An Invalid Character. Help, Please!
Please, tell me to remove error 1324 the path my pictures contains an invalid character. I am a Windows 7 user. How can I fix this bug from my Computer? Reply fast for my problem.
Answered By 0 points N/A #291812
This is due the shell has no correct folder value type or data in the registry is not correct.
To remove this, use the picture shell folder path is set in the registry as per your requirement.
Avoid the invalid character from the registry, install the software by different user accounts.
If you do not have an account, then create a new one and then install the application.
Check your Window Registry has valid way to my picture folder.
Set the Shell folder path to default.
It will help you to avoid your issue.
