Hi Experts,
When I am starting a game on my desktop. It shows the Error: broke desktop game. Please resolve this problem and send me the proper solution for this issue. How can I again start playing games on my desktop.
Julianne Plantz
Resolve Error : Broke desktop game
Hello! Good Day!
You have probably deleted/erased or moved that shortcut icon. Try to locate the directory of your game (Installation Directory). Mostly, if you didn't modify it while installing the game, it is located in C:Program Files*Game name*. Open the folder of the game and locate the .exe file.
Right Click the .exe file then click "Send To" then choose "Desktop" or If you are using Windows 7, you can drag the .exe file and drop it on the desktop.
Hope it helps.
Hi Julianne,
Check what was done on the computer, say an update or probably a new installed software. You also need to check the installation by running a repair. If you still have the CD installer of this game you can use it to run a repair. If all else fails, reinstall the game.
If you receive an error when you start a game, try restarting the computer and try again. If this doesn’t work, check that your computer meets the requirements. If the game was a download, visit the website and check the system requirements. If your computer falls short on the requirements, try upgrading your system or shift to a different game.
Your machine or system must be compatible with the program or game before you can use it. On the other hand, if your system is perfectly compatible, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select the affected program among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then restart the computer and then install the game back.
