harry viktor 20 points N/APosted on - 02/24/2017
Yesterday I purchased a new iPhone and all the features are good such as video game, camera, and phone all good. Only one problem occurs that csr racing game. How to restore csr racing data on my phone?
Game saved manager is an app which stores the games if the data get deleted. It will restore the data of the saved games. All you have to do is, save your game here.
When you first time opens this application in your phone, then you need to configure your program setting according to your needs.
The easiest way to restore your game data from an old phone to a new phone is through iTunes. The majority of applications and games let you transfer data using the built-in iTunes backup service. The process involves connecting your old phone to your computer and synchronizing it with iTunes.
CSR Racing
Then after synchronizing your old phone with iTunes, you then connect your new phone to your computer and restore the data from the old phone to the new phone. The downside of this process is that you need to synchronize everything. You cannot synchronize selectively or create a backup of only a particular application.
If you want to transfer your game data to a new phone without synchronizing everything, you need to backup your game only. To do this, download and install iExplorer. It’s a kind of application that helps you transfer files from an iOS device to a computer selectively to create backup. It supports Windows 7, Windows 8.x, and Windows 10 and requires iTunes.
For Mac, it supports OS X 10.9 Mavericks and higher and requires iTunes. Once it is installed on your computer, download the game you want to transfer data to on your new phone. For example, if you want to transfer your game data for the CSR racing game, download the CSR game to your new phone.
Next, connect your old phone to your computer using the USB cable then start iExplorer. You should see your device in the file browser. After this, click the arrow next to your device name and then the arrow next to “Apps”. In there, look for the CSR game app then click the arrow.
Inside the CSR game app’s folder, you should see a folder called “Documents” which contains the entire game app and game data. Copy the “Documents” folder to your desktop or to your hard drive. After this, disconnect your old phone from your computer then connect your new phone. Follow the same steps to locate the CSR game app on your phone.
Locate the “Documents” folder in the CSR game app then copy the “Documents” folder on your desktop to your new phone. And that should do it.
1....
