My mts blaze setup.exe download does not require any inbuilt software for run internet connection on this. I searched online or any other, but I can not found that software. Please help me where I can download that software and use MTS data?
Resolve Mts Blaze Setup.exe Download Error
There are many official sites available for searching drivers. But if you could not guarantee success to find it.
Then there are some driver finder software tools available. You can also download it.
The link for downloading that driver below:
https://www.driveridentifier.com/,
After completing downloading, you should to install it and scan that driver.
If you are installing MTS MBrowse, make sure you have a supported operating system. MTS MBrowse supports Windows 2000 (32-bit only), Windows XP (32-bit only), and Windows Vista both 32-bit and 64-bit. If you have Microsoft Windows 7 or newer, you cannot install MTS MBrowse.
You need a computer with an earlier operating system or downgrade your current operating system and install one of the supported operating systems preferably Windows XP or Windows Vista. Microsoft Windows 2000 is very old to downgrade your operating system to. If you decided to downgrade to Windows XP or Windows Vista, update it to the latest Service Pack. For Windows XP, download Windows XP Service Pack 3.
This is the latest and last Service Pack update for Microsoft Windows XP. For Windows Vista, download Windows Vista Service Pack 2. This is the latest and last Service Pack update for Microsoft Windows Vista. If you still cannot install MTS MBlaze, visit Sistema Shyam TeleServices Limited India and contact them.
