Resolve My Problem Error Code 121
I am facing the problem of error code 121 on my computer. Can anybody help me to solve my problem, which type of error this is?
This is the error of timeout or the session is expired also known as 0x79. This message is shown on your machine. This issue Occur due to Registry is invalid or corrupted, virus attacks, the driver is not installed properly, damaged file or corrupt.
To solve this fault, make sure to update driver, scan files to avoid the problem use antivirus to remove the virus. Also, try to restore your machine to remove such type of faults.
If that error appears automatically when you start your computer or after booting the computer, you need to check which program among the startup programs is causing the error. To easily figure out which startup program is causing the error, download the free version of CCleaner and install it. Once installed, start CCleaner then go to “Tools” on the left pane and select “Startup” on the right.
Under “Windows” tab, select the first item on the list then click “Disable”. Close CCleaner then restart the computer. If the error appears again after booting, repeat the same steps then disable the next item on the list. Re-enable the previous item you disabled. Close CCleaner and restart the computer. Keep doing this until you verify which application is causing the error.
Once you located the program, uninstall it.
