Resolve TeamViewer A Connection Could Not Be Established You Established And Aborted Bug
Why I cannot connect to other system using TeamViewer? Whenever I try to connect, it shows TeamViewer a connection could not be established you established and aborted error.
Answered By 0 points N/A #289823
Teamviewer is very reliable software for remote users. It gives the freedom to access other system using any device. The error you mentioned can be a human mistake. Be sure you are using right credentials for the remote login.
Check the version of both the system. If you have different versions, then it can be an issue. Be sure that TeamViewer is running on the other system otherwise it would not be possible to connect.
Answered By 590495 points N/A #327715
This problem seems to happen on almost every user of TeamViewer. If you are using TeamViewer for personal use, you need to contact support so they can reset your license. I think that’s the only way you can fix the problem. Go to TeamViewer Personal Use Verification then fill out the form. Explain very clearly that you are not using the software for monetary compensation.
They will help you reset your license. Unfortunately, answering your request may take up to thirty (30) days because of the large number of requests they are receiving. For everybody’s knowledge, TeamViewer is not free software. Though it allows you to use the application for free for personal use, it is actually a commercial software which requires a license.
