Resolve The Connection Timed Out Error For Chrome
I was using Chrome. Once I tried to enter a URL of a website, but I could not see the webpage. It showed a connection timed out error. How can I solve this error?
You can face this issue a lot of times. This mainly happens if your internet connection is weak. It can also happen if the server on the other side has failed or become unresponsive. There is no proper way to solve this error. You can try the solutions given below.
1. Check you network. Make sure the internet is working.
2. Make sure that you have correctly typed the website name in the address bar.
3. Try to refresh the webpage.
4. Close your browser and start it again.
Try using a different web browser. Another way is to troubleshoot your connection. If your computer is connected to a Wi-Fi router using a cable, disconnect the network cable from the network port then plug it back in. Open your web browser and visit a website then try clicking some links. Verify that your internet connection is working.
If this doesn’t work, disconnect the other end of the cable from the router then plug it back in. If this doesn’t work, restart the router. If the router has a power button, press it to turn it off then unplug it from the power for about twenty (20) seconds. Press any button on the router to discharge any leftover power or to power cycle.
After this, plug the router back to the power and turn it on. Wait until the router is ready then check your connection again.
