Resolve The Required .net Framework Is Not Found The Smart Audio Ii Application Will Be Terminated Failure
While using Smart Audio application, it shows an error “the required .net framework is not found the smart audio ii application will be terminated.” Can anyone tell me how to fix this issue?
Best Answer by Sharath Reddy
Answered By 0 points N/A #290017
Be sure that your system has.NET Framework. Check the version of the framework.
If you are using an older version, then it is possible that many products will not run properly because they need the latest upgrade.
You can check the compatible version of.NET for this application and then download the suitable one.
You can get the installer here.
Answered By 590495 points N/A #295638
If that error was caught after running Smart Audio then that means the application requires Microsoft .NET Framework. This also means you did not check the system specifications of the program before you installed it. Problem here, you did not mention what version is required. Anyway, just try downloading one of the following versions:
  • Microsoft .NET Framework 3.5 Service Pack 1 – this .NET Framework version requires Windows XP or Windows Vista. For servers, it supports Windows Server 2003 and Windows Server 2008.
  • Microsoft .NET Framework 4 – this .NET Framework version requires Windows XP Service Pack 3, Windows Vista Service Pack 1, or Windows 7 both 32-bit and 64-bit. For servers, it supports Windows Server 2003 Service Pack 2, Windows Server 2008, and Windows Server 2008 R2 with or without Service Pack 1.
  • Microsoft .NET Framework 4.6 – this .NET Framework version requires Windows Vista Service Pack 2, Windows 7, or Windows 8.x both 32-bit and 64-bit. For servers, it supports Windows Server 2008 Service Pack 2 both 32-bit and 64-bit, Windows Server 2008 R2 Service Pack 1 64-bit only, Windows Server 2012 64-bit only, and Windows Server 2012 R2 64-bit only.
