Whenever I want to open a word document in my system, then it gives me a winword.exe 0xc00007b error message. I tried to reinstall and start it again, but the same message pop up again. Can you tell me the solution of this message?
Resolve Winword.exe 0xc00007b Error.
This error mainly occurs on 64 bit OS when a package cannot configure correctly, and the package is Microsoft Visual C++ this gives the error.
For removing this issue,
Download the Microsoft Visual C++ and launch this application.
Select all the terms and condition and license agreement and install this application.
If you already tried uninstalling and reinstalling Microsoft Office Word but it didn’t fix the problem, this time try reinstalling the entire Microsoft Office suite. The problem is probably not with the Office Word application itself but with a component used by the entire Office suite. The most recommended solution is to uninstall and reinstall the program. Download Revo Uninstaller Freeware 2.0.0.
Follow the instructions to download and unpack and then install it. Once Revo Uninstaller is installed, run it then select Microsoft Office from the list and then click “Uninstall”. Follow the instructions to completely remove the program. Restart your computer if you are prompted. Next, download and install CCleaner. Once installed, start CCleaner and clean your system. After this, install Microsoft Office back and see if it works.
If you want to register CCleaner, download CCleaner Registration Codes and follow the instructions.
