Resolving Error 1935 While Installing MS Office, Showing ‘error 1935 Installing Office.’
I just tried installing Microsoft office until I received an error like ‘error 1935 installing office’. What could be a possible solution?
Hey there, Error code 1935 is related to the incompatibility of .NET framework. Numerous other reasons could contribute as a part such as outdated system drivers, unfinished installations, corrupt registries and much more.
You can try fixing .NET framework configurations. Before that, see if it is installed already. Then update it to the latest version. In case this doesn’t help you out, refer this link to the official documentation of this error. Hope it helps!
This error is triggered when you have Microsoft .NET Framework 2.0. The installation may fail when an MSI file (.msi) tries to install many policy files which then trigger the “error 1935.” This happens because the registry handles leak. This leak causes an out of source exception error that’s why the installation fails. If you have Microsoft .NET Framework 2.0, try installing its latest Service Pack.
Or better, download Microsoft .NET Framework 3.5 Service Pack 1. This update contains .NET Framework 2.0 Service Pack 2 which replaces and updates your existing Microsoft .NET Framework 2.0 component. See if this fixes the problem. Since you didn’t mention what version of Microsoft Office it is you are installing, check your version’s system requirements and make sure your computer meets the requirements.
Though the program you are installing may not require a version of Microsoft .NET Framework, the error is normally caused by Microsoft .NET Framework 2.0.
