Resolving The Issue With The ActiveX Download Microsoft Windows 7
I am facing issues while installing the ActiveX download for Microsoft Windows 7. How to work around the installation issue for the ActiveX download Microsoft Windows 7?
This is Profile issue.
Microsoft has affirmed this to be by the outline in Windows.
WORKAROUND
To work around this issue, you can utilize the progressions beneath to physically rename the profile way.
• Sign in by utilizing another authoritative record. Note: You may be required to make another managerial record at first.
• Go to the C:users envelope and rename the sub organizer with the first client name to the new client name.
• Go to registry and adjust the registry esteem ProfileImagePath to the new way title.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionProfileListUser ID
Cautioning: If you utilize Registry Editor erroneously, you may bring about major issues that may oblige you to reinstall your working framework. Microsoft can't promise that you can take care of issues that outcome from utilizing Registry Editor mistakenly. Use Registry Editor at your personal particular danger.
• Log out and sign in again by utilizing the client whose name is modified, and the client ought to utilize the previous profile with new way name.
