Resolving Server Endpoint Error 1753, No More Endpoints
Joining domain of Active Directory to a client causes the Error code 1753, a dialog which says ‘error 1753, no more endpoints available’. How to resolve this issue?
Hey there, processes in windows communicate among with each other, within the system or across the network with a procedure called Remote Procedure Call or RPC. This error occurs when something hinders this RPC process.
See if the Antivirus or the Firewall is creating problems. If so, disable them.The service used by the client must be running on the target server. If there are no issues as stated above, look for this link for further references by Microsoft. Hope it helps!
