Resource instance dependencies management error
Hi friends
I am using the HA setup of AMX BPM1.2 HFO1. I had to change the emergency management services (EMS) transport to a fault tolerant system. I also changed the EMS connection string in AMX GUI. After I changed the string, AMX BPM is not properly initializing. I tried to fix it by undeploying it and also by removing all the deployed applications. I also cleared all the server queues but still ended up in the same problem.
When I deployed the AMX.BPM.APPP I got a warning message. The warning message said:
The system has discovered the following issues that need to be resolved in order to process your request.
 Resource instance tibco/amx/platform/transport/gms is not installed for node 'BPMNodeft1' on host 'SystemHost'. It is required by property 'groupConnectionFactory' on component. 'ProcessManager/implementation-bx' and has been sourced to property 'qin_property' on composite 'rootComposite'
The screenshot of the warning is attached below:
Any helpful suggestions are most welcome.
Waiting for your replies
Thanking you loads
Regards
Paul
