Hello expert, I need some resource projection sheet for my business purpose to enter most data into it. Is there respectable resource projection sheet on MS excel or where can I find the proper resource projection sheet to continue my task?
Respectable resource projection sheet on MS excel
Greetings Allen Etthan!
I have read your problem about Resource Projection Sheet unfortunately I don't find exactly the same as what you wan't but I have here a similar one. Please download this Resource Planning Sheet, it also contain a resource projection sheet. Here is the link for the Resource Planning Sheet.
Best Regards,
Jose D Dunn
It is possible in both ways you can design a resource projection sheet in excel or you can download it from the network. Here i will first tell you how to design it in MS excel by just following the simple tasks like:Â
Open the MS Excel and Create a spreadsheet for the Work Plan now insert the column names like task, data and effort hours and then create a new spreadsheet and in this spread sheet insert a new pivot table and set it for the right responding select from the pivot table field list and then go to your main spreadsheet and start writing about that.Â
