Restarting PC after uninstalling software
Is it possible to bypass the restart process after successfully uninstalling certain software from almost 100 servers? If yes, how?
Hi Tricia,
It may not be best to bypass the restart process after uninstalling or reinstalling software and hardware on a computer or server. Those restart are important because only then the changes can be implemented.
But you can bypass the restart by changing and amending the registry. To do that, try to amend and check the 3 entries below:
· go to Start > Run > Type regedit > go to > HKEY_LOCAL_MACHINE > SYSTEM > CURRENTCONTROLSET > CONTROL > SESSION MANAGER > PENDINGFILERENAMEOPERATIONS. Set Requires Restart – Anything. Set Doesn’t require restart – blank;
· Look if you do have a file or entry HKEY_LOCAL_MACHINE > SOFTWARE > MICROSOFT > WINDOWS > CURRENTVERSION > WINDOWSUPDATE > AUTO UPDATE > REBOOT REQUIRED;
· HKEY_LOCAL_MACHINE > SOFTWARE > MICROSOFT > UPDATES > UPDATEEXEVOLATILE:FLAGS. Set Requires restart – anything. Set Doesn’t requirerestart = 0(zero).
Aristono
Restarting the system after a successful software installation is really important so that the changes the installation made to your computer will be implemented and started after rebooting it. But there are times restarting the machine is really not an option because of so many programs running and you can’t stop what you are doing. Besides following the steps described above which I’m sure will affect the whole system since it modifies the registry, here is one that I’m sure is the best method of bypassing the required system restart after an installation.
And you’re done. Your system has now been refreshed as if you already have restarted it.
Aristono Martin and Sharath Reddy thanks for your eligible comments. I have remarked to Sharath, since I have not seen anyone who has penetrated so clearly before. By going through your comment I have enriched my knowledge why I need to do this task, which tips were not known to me prior. Your step by step process was really the best one, which was proved by applying this process on my PC now. My system unit is running smoothly now without any error that pop up. Thanks Sharath, for your cooperating to refresh my system and Techyv too for revealing this superb post.
Hi
Check out this Techyv post. This post will be also helpful for you. Go that page and get more idea to fix this issue.
