Restore Deleted Contacts in Outlook 2007
I am using MS Outlook 2007. I unintentionally deleted few contacts on my address book.
And now I am searching everywhere for solutions of restoring those contacts.
I am not a geek when in terms of Outlook since I only used this for sending and receiving mails.
Is there any method that I can restore my deleted contacts?
Please help me.
Best Answer by Zorian Crust
Answered By 80 points N/A #120782
Hello Victor,
Below is my recommendation on how to recover your deleted contacts on MS Outlook 2007.
  • Download the Data recovery Tools in this link.
  • Install and then launch the software
  • 2 options will appear after launching which is Outlook Express Email Recovery and Microsoft Outlook Email Recovery which is show in the picture below
  • Choose Microsoft Outlook Email Recover
  • Restore the deleted PST items as .eml, .msg or .pst format
  • An output screen will allow you to preview all the items that you want to recover
I hope that my solution will help you fix your problem.
Zorian
Answered By 0 points N/A #120784
Hi Dear!
I have a solution in this concern because I faced this problem earlier and concluded some priority wise remedies.
  1. If you have some back up files in connection with your mails as well as your contacts, then try to restore them in accordance with their definite rules.
  2. Stellar Phoenix is a third party utility, which uses full software in the email recoveries, I would like to tell you that it’s a freeware but free version is limited to just view the mails and contact. If you want to recover through this software you have to purchase it.
  3. Through, mentioned above software you can find the contact data at default location or where you wish to store.
  4. Similarly, you can retrieve/recover data in accordance with your emails at your defined/default path [which can be in .pst, .eml or .msb file formats, it’s up to your selection].
  5. The software is useful for Win 7, XP, Vista, Win 2003, Win 200 operating systems as well as the results is good enough after even a fatal virus attack.
I am sure you can recover your mails and contacts keeping in view my remedies.
Good Luck
