Restore old toolbar icons on web browser
I need a detailed procedure on restoring my old toolbar icons on my web browser.
My PC keeps freezing all the time since I installed a new one.
Is there a known solution?
If your computer frequently freezes, maybe it is not your web browser that has the problem.
Try to run a disk check on your computer to see if there is an error in its file structures that causes this frequent hang ups.
If you have a disk utility application installed on your computer use it instead.
After the disk check open your web browser again to see if your computer still freezes.
If the condition is still the same, uninstall your web browser and then install it back afterwards.
This will revert all the toolbars back to its default icons.
Just change the toolbars’ icons to the ones you like after the installation to customize it.
Notifications
