howel dinh
30 points
Posted on - 06/06/2020
What steps to follow to restore the backup of an Active Directory (AD) 2003?
Restoring: Active Directory 2003
These simple steps would surely help you to restore the Active Directory:
- After you start the system, press F8 to restart the system in Directory Services Restore Mode (DSRM).
- Select the Directory Services Restore Mode (Windows domain controllers only) once you have selected it.
- Select the operating system that need to restore after start.
- Log-on as an administrator.
- In the command prompt, type ntbackup, and press ENTER.
- The Welcome page appears, click on Advanced Mode, and select the Restore and Manage Media
- Select the appropriate backup file from which we have to restore from and check that System disk,and System State, also make sure check boxes are marked right.
- Click Start Restore.
- When the restore is complete, restart the system.
