I have a question regarding Photoshop. Do I need to restore it to its default to be cleaned? And if any problem arises, is it safe to restore it repeatedly without damaging the software? Please send me some suggestions. Thanks.
Jackman
Restoring Adobe Photoshop to Default
To clean your Adobe Photoshop you may use the Adobe Creative Suite Cleaner. This tool helps restore or resolve installation problems in Adobe. It can also help your remove previous installations if you want to. Before you start ensure you files are backed up otherwise you risk loosing them.Ensure you read the ReadMefirst.pdf that is normally downloaded with the Creative Suite Cleaner. Ensure you back up all the files that are stored in Adobe before you start. Then uninstall any Adobe Creative suite that was previously installed before you install the version that you want to use.Use this to clean your Adobe rather than putting it on default which may lead to corruption of the version installed.
