Restoring Files Using Acronis True Image Recovery Disc
HI tech masters out there!
How can I recover my files and data using acronis true image recovery disc as I am completely new and want to know how to use this software.
hi! Kindly follow the following steps for using acronis true image 2014 premium, and of course, you need to have the software too.
1. Open your software Acronis true image 2014 premium, it seems pretty organised even for a new because a toolbar is provided at the very left with all the options.
2. See at the toolbar you’ve got a option their i.e., recovery click over it and a new main screen pops up with a option of browse for backup on it.
3. Click browse for backup and select the file whatever you want to get recover with and you see a file stored on the main screen under the title my backup.Â
4. Now go on the toolbar and click on Home, and then you see two options on main screen either to backup or to recover. Select over the recover option and again choose the backup file from the local disks and click on next.
As you select you now see a next option down on the screen click over it and choose your items and recovery options as offered and press next and also specify the settings for the partitions.
Mainly use new location option present there and proceed.Â
5. A dialogue box pop up asking your permission ,grant the permission and accept and then read the summary and proceed and hence recovery is done .
Hope that helps .
