Restrict people to save HTML pages
There are really no sure ways of preventing other people from saving a webpage or maybe from saving your website’s own webpage. The latest versions of web browsers that are being launched nowadays include the function of viewing the source code of the webpage or every webpage you have visited. This function is not only present from the versions being launched today but is supported in all versions of web browsers even from the very first version created. And most especially, web browsers have the ability to save web pages as an HTML file.
There is really no sure fire on this. If you don’t want others to save your website’s page then you should not have published the webpage after all. There are options to disable right-clicks on a webpage to prevent your images from being copied by others but this doesn’t prevent the user from viewing and accessing the source code of the webpage.
In general, just about all internet sites are generally readily readable by simply any individual who would like to see these individuals. Needing a new end user label in addition to private data gain access to several hypersensitive areas of your website means that you can restrict access to merely a picked couple of those who realize the secret unique codes. Restricting access:
Create a directory for the password file.
Create the password file.
Create a .htaccess file.
