Restrictions about writing blog sites India
What are the main restrictions about writing blog sites India culture and traditions? I want to construct a historical buildings site of India.
Best Answer by Drianna allen
Answered By 30 points N/A #147943
Hello.
There is no such restriction for writing blog about India culture and traditions.
But you have to keep in mind that whatever you right should be true and correct.
India is a land of many religions with different cultures and traditions.
So you must be careful while writing and take care that it doesn’t hurt any ones beliefs.
Thank you.
Answered By 0 points N/A #147944
Hi Dudley,
There are no restrictions as such on what you can and what you cannot write on a blog in India.
However, you need to always make sure that you don't hurt the sentiments of a particular section of the society. India is a very diverse country, with all kinds of people, various backgrounds, various religions and various cultures. You just need to make sure what you write does not undermined a certain section of the society, and I guess then everything should be fine with you.
What you are doing is a very noble thing, good luck for that!
Drianna allen
