The results to send email with a custom sender?
What are the results to send email with a custom sender since this is the one use for legitimate business purposes allowing the sender the privacy?
Hello David,
Because you are using this for legitimate business purposes I recommend you to use Persona to send mails with a custom sender name.
Other method is setup ISPConfig 3 and set up a mail domain and easily sends the mails with custom sender names.
Guide to set up mail domain and mail client
Thank you.
Rubi Sharlene
Hello David,
If you are using custom sender option than you will send emails without your name put as sender on it.
In my opinion if you are having some business that have a lot of money and is growing up you should not use this type of sending emails.
Maybe I am wrong, but my suggestion is not to use it.
You can hear my opinion or just try how this will work.
