Noreen
Posted on - 12/19/2011
Dear all,
This problem I don’t know how to fix and I really need help. This situation is similar even if I want to save PDF or any other format and even if I want to send invoice I got the same error message. On my computer OS is Windows Vista. Please help
Thank you in advance
Noreen
Warning
C:tempSI22.pdf could not be created due to error#-121
Retail Man error #- 121
Noreen
Warning, if your computer has started showing error 121, it means that you should be alert, as this error means that the more obscure problems can occur. Start paying attention to slow computer performance, Blue screen of death, network connection issues, dll or exe errors, corrupt log files.
The reason for these could be spyware attacks, invalid registry keys, low disk space, damaged driver versions.
The only way to address this issue is to be able to have a complete instant scan of your computer, with Malware scanners, registry checkers,etc.You can use multiple softwares for this purpose like,
MALWARE Bytes from https://www.malwarebytes.com/,
CCleaner from: http://www.piriform.com/ccleaner
Dll-Files.fixer from: https://www.dll-files.com/
There is another option, you may go for software / tool which contains the functionality of all the above with a special reference to fixing the 121 error, and that is: AdvancedPCTweaker from: https://www.malwarebytes.com
PT
