Retrieve files permanent deleted accidentally
What should I do for me to retrieve files from my mac book that are permanently or accidentally deleted?
By following these simple steps you can actually retrieve your data:
Good luck!!!
It seems that this is another case of accidental file deletion and the user doesn’t have any clue on how to retrieve them back. The first thing to know whenever a file has been accidentally deleted is not to copy or move any files to the drive where the deleted file is located. This is to ensure that the file has a great chance of being recovered although it still doesn’t guarantee the successfulness. If the file is located on drive D, you can install file recovery tools and the best recovery tool for this kind of problem is Ontrack® EasyRecovery™.
This is the very first file recovery tool I used when I first had my first computer running Windows 95. And I’m still using it until now even if it’s already a very old version because it’s still very effective. Download the latest version of Ontrack® EasyRecovery™ from Kroll Ontrack | Data Recovery | File Recovery Software. It works on Microsoft Windows and Mac OS X. Download this application and then install it on drive C. After that open the program and then scan drive D. It will display all deleted files on the drive as well as its characteristic if it is cross-linked or what. See if you can find your files using this tool and still be able to recover them.
