Retrieve photos from a damaged memory stick
Hi Techyv,
I have a problem with my memory stick.
Its plastic brackets broke off and now the memory stick itself won’t connect to my computer, not even on a photo kiosk.
Is there still a chance for me to retrieve the photos stored in my memory stick, and if so, can you give me step by step instructions on how to do it?
I hope you can help me.
Thank you very much.
Best Answer by maaneshka
Answered By 0 points N/A #110977
Hi there!
There are several recovery software,s that can be downloaded online. They can help you retrieve lostphotos and files.
Here are the lists of some known software:
1. CardRecovery – It is known to be the leading photo recovery software for memory card. It effectively helps with the retrieval of lost, deleted, corrupted or formatted photos and video files from memory cards. It supports almost all memory card types including SD (Secure Digital) Card, CF (Compact Flash) Card, xD Picture Card, Memory Stick, MicroDrive, SmartMedia Card, MMC (MultiMediaCard), MicroSD, MiniSD, SDHC and more.
https://www.cardrecovery.com/download.asp
2. Remo Recover – recovers corrupted photos from memory card. Has a preview feature that allows you to evaluate the recovery results.
https://www.remosoftware.com/download
3. PC Inspector – A windows-only software that ecovers unintentionally deleted or formatted  pictures from any storage device used on digital cameras.
http://www.pcinspector.de/
Answered By 10 points N/A #110978
Hi
I am very sorry to tell you my friend. You are in a great trouble.
I also had the same problem few weeks ago.
Yes there are lots of free software’s in the internet that can recover damaged flash drives. But the capability will depend on the damage that happened to the pen drive. If the pen drive dose not connects through the USB port there is no use of any software that you are using.
So if it is damaged you can’t use it further. So the best thing you can do is go to the person who repaired Storage device and ask him to take data that contains.
But if the damage is serious if will also impossible.
Thanks
