Revaluing faded portraits in Photoshop
Hi
I have adjusted all the settings correctly, open aperture, low tele focal length, classic picture composition. But my portrait still appear faded.
Can anyone help me?
Thanks
Hi
Can anyone help me?
Thanks
Hy,
Here I am trying to give the solution regarding your issues. Here following the steps below:
Thanks
I suggest you to follow these troubleshooting steps to fix the issue:
>> Open the faded photo, press Ctrl J and duplicate the layer.
>> Choose enhance from the menu bar and select ‘auto levels’.
>> Press Ctrl J again.
>> Go to blend mode menu. Then click on multiply.
>> Please lower the opacity until the image looks good.
>> Press Ctrl E with the top layer selected.
>> Click on the ‘eye’ icon to hide it so that you can compare with the original.
>> Now save your image in a JPG and rename it.
That’s all.
Thanks and regards,
Skarbos Jay.
Notifications
