Reverse Engineering on Database Reporting Tools
What does "reverse engineering" on Database Reporting Tools implies and what in is specific does it do in database systems?
Are all database reporting tools available in the market today have this feature?
I would appreciate to hear your detailed opinion regarding this database feature.
Thank you.
Answered By 95 points N/A #103187
Actually you can create a model of database from an existing database with reverse engineering database tools. This model show you the graphical view of the structural database and their elements. If you are a database professional, on database engineering tools reverse engineering is a features that is work to help you about this task- it provides the capability to document your all database graphically. Visit here for a detailed process- http://www.sandhillconsultants.com/
You can’t found this interesting features in all database engineering tools. So you can use Sandhill, I suggest you before. Also you can find reverse engineering features in ER/Studio Data Architect. It is help you do a lot with your database. It’s a industry leading tools of data modeling.
Hope this all suggestion makes you relief.
