Review Emsisoft Emergency Kit 2.0 FINAL
The latest version, Emsisoft Emergency Kit 2.0 FINAL is a good one. Is there any problem if it is used with AVG antivirus securities?
I think this is not actually an antivirus program. It is only a set of tools or collection of tools that will help you in cleaning up an already infected computer. I don’t see any problem why you can not use it together with your AVG antivirus.
You can try it on your computer if your machine is already running with AVG antivirus to really check if there will be no conflict between these applications.
If ever you find some problems while using it together with your AVG antivirus, you should disable your antivirus first before using Emsisoft Emergency Kit.
Emsisoft Emergency Kit 2.0.0.8 works on Windows XP, Windows Vista [32-bit and 64-bit], and Windows 7 [32-bit and 64-bit]. It’s a freeware so you don’t have to worry about any expiration period. If you want to download its installer again, you may visit DownloadCrew — Emsisoft Emergency Kit 2.0.0.8.
To download Emsisoft antivirus, internet security, firewall protection, or to download Emsisoft Emergency Kit 2.0 again and other Emsisoft products, please visit Emsisoft.
