I am using Windows 7 64 bit and trying to install AutoCAD 2013. I downloaded the 64 bit installation exe and during installation I get the following error message. I would really appreciate any help from experts.
Thanks in advance.
1:52: adlmPITSetProductInformation failed.3:2
Revit 2013 installation error on Windows 7
This Productinformation.pit file is just like an Excel spreadsheet. It records all the 2010 & 2011 products of Autodesk that are installed on your computer.  The file will be present when you install the Standalone or Network versions of this software.  To remove this error, remove the Productinformation.pit file. I am sure that the error will not appear again.
