Revo Uninstaller Pro for uninstalling applications
Hi Guys,
I need Revo Uninstaller Pro to be installed in my system, Please do let me know, where should I freely download it. Also help me by providing details on using it for uninstalling  any applications / programs.
Thanks, Cruz D Hatchell
Best Answer by Sharath Reddy
Answered By 5 points N/A #145871
Hi Cruz,
Revo Uninstall Pro is an application which allows you to uninstall and remove unwanted or useless softwares. You can download the free 30 day trial here http://download.cnet.com/Revo-Uninstaller-Pro/3000-2096_4-75016166.html and on that link you can also buy it there. Revo Uninstall Pro is compatible with Windows XP, 7 and Vista.
There are the ways on how you can un-install your useless application:
1.       The Unistall
2.       Quick Uninstall
The difference of the two is the "Uninstall" allows you to opt out in removing all the leftover files.
Here are the ways on how to use "Uninstall"
Step 1: Launch Revo then click "Uninstall" and the uninstall wizard will appear.
Step 2: Revo will create a registry backup and system restore
Step 3: Revo will run the Uninstaller, wait until it's done.
Step 4: You need to scan your system. Choose the scan typed you want between Safe, Moderate and Advanced then click "scan" to continue.
Here are the ways on how to use "Quick Uninstall":
Step 1: Choose and select two or more software from the list of applications installed.
Step 2: Click the "Quick Uninstall"
Step 3: The installation window will appear. Wait until it's done
Answered By 590495 points N/A #145872
Sometimes there are applications you install on your computer that you don’t know don’t have their own uninstall programs with them and these programs don’t usually appear in the Add or Remove Programs in the Control Panel. I am a usual victim of these types of programs that normally comes together with another application as a bonus or feature product.
It’s not a problem for me to remove these types but for beginners, it sure is hell. To help you solve the problem on removing stubborn programs, Revo Uninstaller is your solution. It will easily help you uninstall applications including unwanted programs from your computer. Even if it seems it doesn’t have any option to remove it because it doesn’t appear in the Add or Remove Program, Revo Uninstaller will remove it.
Here are several of the reasons why consider using Revo Uninstaller:
  • It can remove the unwanted program that easily.
  • No more stubborn programs that don’t want to be uninstalled.
  • It removes leftover data of previous regular uninstall.
  • It can help you monitor what the program changes in the system during its installation.
Revo Uninstaller is powered by a very powerful feature called Forced Uninstall which is the major component in removing stubborn programs, partially installed and uninstalled programs, and those programs that are installed but are not listed as installed. To try the program’s free 30-day trial period, visit Revo Uninstaller Pro.
It supports both 32-bit and 64-bit versions of Windows XP, Windows Vista, Windows 7, and is already compatible with Windows 8. For more information, watch “Revo Uninstaller Pro – install & use | video by TechyV”.
[video:http://youtu.be/ebW8CD6cB1U]
