I am always comfortable using Revoice audio software but recently i am facing problem regarding this software. This software is showing following error message. can anyone help?
Authorization Error:
Revoice Pro cannot run. Required software is missing
or not running. Please reinstall the product, or
download and run the driver installer here http;//
www.paceap.com
OK
Revoice pro is displaying authorisation error
As you see the Error Message when you try to start Revoice Pro, you should install extra it ok software.
Install the extra software:
1. Open the file 'RevoicePro.dmg'.
2. Open the folder 'Extras'.
3. Run the program 'License Support.pkg'.
After completing the process, install the Revoice audio software normally.
I think your problem will be no more.
Hathy
Hello Janis,
This is a license related authorization issue. To solve this fully, you need to get a iLok license of Revoice audio software. Follow the link to get the iLok license: http://www.synchroarts.com/ . Syncro Arts will deposit a license into your iLok.com account and notify you if you have obtained a trial license or purchased your software.
Thank You. Hope this will solve the issue.
Paul Jolie.
