RGSS error occurred when tried to navigate the map
The following error encountered when I navigate the map or change the menu.
I can’t resolve this problem without your help. Provide the proper solution so that I may continue my work.
Any help would be greatly appreciated.
Lazarus Regress
Script ‘Ace Enemy HP Bars’ line 388: RGSS Error occurred.
Disposed plane.
Answered By 5 points N/A #176536
Hi!
Here I am to provide you with proper solution to solve this problem.
First of all, your problem might be because of the failure to create bitmap.
If you see the RTP, please try to delete it. This is because RTP will stop your program when in use.
Otherwise, please try to remove Character image or option from GraphicsFaces.
That Character image usually will causes an error to your program. Thus, to avoid your program from crashed, just simply delete it.
Hopefully these steps can provide a vital solution for you.
