How do you delete ringtones that you added with Ringtone Maker from iTunes?
Neena
Ringtone Maker / Deleting Ringtones From iTunes
Hello Felix,
To delete a ringtone from your iTunes completely, you have to do these simple steps.
Firstly, connect your iPhone to the system.
Now click on your iPod showing in the left side list with your IPods' name.
Now locate that file, you wants to delete. Right click on that ringtone file and click on the 'Delete''.
Now it will show you a dialog box that you want to remove or not. Then click 'Remove'.
Now to remove completely it from the iPhone you have to re-sync the iPhone completely.
Done!
Certainly, you cannot delete ringtones from your phone that came pre-installed.
But those that you purchased from iTunes and saved in your phone can surely be deleted anytime.
There are many different ways of deleting ringtones from your Smartphone either permanently or temporarily.
But you can only do this from a computer and not from your mobile phone.
See the steps below.
Open iTunes from your computer then connect your Smartphone using the USB cable.
In iTunes under Devices, click your iPhone.
Click Summary tab then put a check on "Manually manage music and videos".
Click on the small arrow on the left of your iPhone’s icon. This lists several of the folders saved in your phone containing books and media.
Click on the Ringtones folder.
Select the ringtone you want to delete. If you want to delete several ringtones, press and hold the CTRL key while clicking on multiple files.
Press the Backspace or the Delete key from your keyboard to immediately delete the files.
For more information you may visit.
