Risks on disintegrating VPN on two Windows Server 2003
Can somebody disintegrate VPN between two Windows Server 2003? What are the basic risks in this regard? Can this be reduced by using CISCO’s hardware?
That may be good but also not good part. The good part is that you will have two servers and therefore in case one has problems that cause it to lose information then you can have another copy on the second server. But that is something that you will not expect to happen because even with one server backups are performed regularly so as to keep the network safe from the risk of losing data. I will strongly advise that you stick to one server because it will be easy to manage compared to two, and instead of using two you can upgrade one and make sure that it has enough space to host as much data as possible on the network.
Regards
Thompson Locker
Notifications
