RoboForm Editor Fails to Launch: Error Storing RoboForm Settings
Hey guys,
Can you help me out here?
Whenever I open RoboForm Editor, a dialog box appears with this error message:
Hey guys,
If RoboForm is giving you an error when saving your current settings because the old profile still exists, try renaming the old profile name to a different file name if it is possible. Or do the other way around, save your current settings to a different profile name or which is possible. If it can not be done, try uninstalling then reinstalling the application. This will make RoboForm’s settings back to default and removing all the previous settings including some customizations that you did.
If you are using the older version, try upgrading to RoboForm 7.3.1. You can download the latest version atÂ
