Hi experts,
Recently, I downloaded ROBOTC successfully on my Windows XP Operating System but when I attempted to install this program an error message displayed showing “Could not initialize application”. How can I remove this Error 42 (IPM)? This is very annoying to me because I can’t continue my work so please guide me with best solution.
Thanks in advance.
Could not initialize application. Error 42 (IPM) Please contact technical support
ROBOTC installation error on Windows XP
Hi Wade S Veith
This error is related to permissions. You are login with administrator and then install the program.
Try these steps it may be helped you
Select the window button from your keyboard. Start screen has been appearing.
Right click and select all applications
In the Electric Quilt press the EQ6
In the list which are shown on screen select the run as administrator.
Select the yes for allowing the EQ6 to run
Following link this help you more
Helping link
Regards From
Whitaker Sorg
