Roccat with its PC controlling Smartphone App
I’ve heard that Power-Grid is designed to let gamers use their Smartphone as a second screen. I’m on for knowing the potentials of this App. Can anyone help with it?
Yes, well said you can use your Smartphone in gaming by the aid of Roccat Power Grid. This is an application that will let you control your computer games and PC. This application complies two parts the Power grid for your Smartphones and the program called Power grid launcher with your PC. Once these two are connected you can now control your games thru your Smartphones by the help of WiFi.
The ROCCAT Power-Grid is an advanced fully-customizable remote control for your Windows PC. The application allows you to connect, monitor, and control your games and PC directly from your Smartphone. The best part of it is that the remote control application is absolutely free.
To use it, you need to download and install two apps, the host software which is the one for your PC and the other for your Smartphone which is the mobile app. The host software, the one you install on your PC, is the engine of Power-Grid. This is the program that does all the work. It processes and delivers everything before passing it on to the mobile app.
You can download the host software and the mobile app from ROCCAT Power-Grid Download Page. The mobile app is available in Android and iOS versions. The Android version requires Android 2.2 Froyo and later. The iOS version requires iOS 6.0 and higher.
