RokWeather Time module has XML Parsing Error
Hi there,
I am having problems with my RokWeather module. I saw the error just today when I enabled the module. I have already downloaded the newest version hoping it'd solve the problem but it didn't. It also says that the 'position is bad'. What does that mean?
The error message is as follows:
XML Parsing Error at 2:26. Error 7: mismatched tag
The module was running very well before but it suddenly stopped working. As I've said, I already installed the latest version but that didn't change anything.
Really need your help here. Thanks!
Answered By 0 points N/A #93232
Hi
The problem you are telling is that you XML module is not working properly. This is due to the fact that the module you have downloaded is not fine because of:
1. The coding of the xml is not fine so the coding of the xml is not fine so you need to change that coding which might not possible for you
2. The second option is that your template is not compatible with the version you have downloaded of the module so you should check it before installing the module on your webpage.
3. The other option is that the version of the software you are using for developing the webpage might not compatible with the xml module so you should check this one and make it confirm.
Therefore it is also asking that position is not fine.
The solution is that find another module which should be compatible with the version of software and the template you are using and then install it will work.
