Roland SC-545EX printer doesn’t firing black Ink.
Posted on - 07/16/2011
On my test print this morning, I found that the black ink is not firing or not printing. I do cleaning the head as well as pumping the head manually. I also check the tubes from the Ink bag down on the dumper.
The ink flows so smooth and no problems detected on the ink tube. I can pump ink on from the head. What is the problem? How do I fix this?
