The role of simulator in blackberry 10 cascades in detail
Hello Every One, I am new to blackberry 10 cascades.
While I am running  a sample application.
I am getting following error Deployment Failed: Sending Request: Install and launch .
Please let me find the importance of VMware and simulator in blackberry and the steps to connect simulator with IP address.
Answered By 40 points N/A #166511
The installation of VMware is important in that: It enhances the performance of the workstation support for the graphics, supports operations such as sharing of folders, dragging and dropping operations, improves video graphics compatibility, improves network performance and compatibility and eases up mouse synchronization with host operating system.
Simulator facilitates connection using Telnet, FTP or SSH, configuration of snapshots for debugging your application, it simulates features such as zoom, rotation and tilt and lets you use hardware accelerated GLES 1.0,1.1 and 2.0 for native games and cascades.
You can connect blackberry 10 simulator with IP address using Telnet of FTP.
Using Telnet:
  • Get the IP address displayed on the lower left corner of the simulator screen.
  • In a command window, type Telnet<IP address of a simulator>
  • When you are prompted to login, type “devuser”(with no quotes)
  • When prompted for password, type “devuser”(with no quotes)
  • Resize the simulator to fit the monitor, use ves-zoom<percentage> command in telnet.
