Rom for htc diamond promises best speed boost
Is it correct that you will have better speed boost if you have Elite Rom for htc? How it works and why it is so good?
Yes it speeds up your phone as it has lower voltage limit.It is good for users having low battery issues as it uses less battery.
Yes. Elite ROM for HTC Touch Diamond such as Blade Elite ROM is built on the HTC's stock update. It can optimize your RAM to make it fast and quick, it can also provide custom wallpapers, best battery life and a lot more features that can boost and will help you customize your device according to your desire.
However, Elite ROM will require you to root your HTC Touch Diamond, which means, it will void all the warranties of your HTC phone. And we, here at Techyv.com doesn't allow this kind of action. We do not allow rooting or jailbreak of any device.
